07-20-2009 08:03 PM
Trying to open RME in LMS3.1 - I get HOME0004 error - unable to retrieve out-of-sync data. I have attached the RMEHome.log that details the error. I currently have the same privs that were present under LMS2.6. Note: sometimes this works, most of the time it doesn't.
Solved! Go to Solution.
07-20-2009 08:13 PM
Are you integrated with ACS ? This message can happen when the integration have not been properly made with ACS.
You may want to reintegrate LMS with ACS.
07-20-2009 08:13 PM
07-20-2009 08:42 PM
This is most likely CSCsq83188. It is fixed in LMS 3.2.
11-20-2010 09:07 AM
Hi:
How can I get more info about this bug CSCsq83188?
Bug Toolkit shows nothing about it
I guess this bug affects only RME running on Solaris, for I cannot get it over Windows?
Is there any patch without installing LMS 3.2 (may be installing next RME version?).
Thanks a lot
Julio
11-20-2010 09:21 AM
This bug was a bit of a mystery. It only was seen internally on one server, and results from an ACS authorization problem relating to a device. The fix for CSCsq72947 also fixed this problem. The problem affects both Windows and Solaris. No, the only fix is to upgrade to LMS 3.2.
11-20-2010 09:34 AM
Thanks a lot Joseph!!!!
