RMON using SNMP
manish_3191
Hi Team,
I want to capture traffic for particluar server connected to one of port on cisco switch.
Ho can i do it using RMON using SNMP?Also how would i know which MIB varible to use for interface traffic tracking?
Can anyone guide me n this?
Manish
Joe Clarke
Cisco switches do not support the RMON capture group.  You will need a switch probe or Network Analysis Module for this.
When you say traffic tracking, do you just want to get a count of bytes switched through the interface, or are you looking for a more detailed breakdown of traffic?
Hi  Joseph,
Thanks for your response.
I just want to find out the top talkers to one of server.I want to capture the traffic coming in and out of the interface.
I came to know that RMON is not capable of getting the same result.So i am thinking of Netflow OR RSPAN.
Do you have any suggetions?
Thanks & Regards
Manish
NetFlow or SPAN would both work provided you have a collector that can analyze the data.  As I said, the Network Analysis Module, which is an appliance, Cat6K module, or ISR module can process NetFlow data (as well as act as a SPAN destination).
