Route-map probleme
youssef_bensouda
Community Member
we have a cisco 2801 with 2 WAN interface
isdn and ADSL
and all data comming from eth0/1 is routed to te serial 0/2/0
i try to redirect all data comming frome
eth 0/0 to ADSL with route-map lan0
it doesn't work untill i create a default
route 0.0.0.0 0.0.0.0 dialer 0
and if i did it :
all traffic coming frome eth 0/1 is blocked
normely if i did a route map it doesn't need a default route i think ?
her is my configuration (when i can't be connect to the internet frome eth 0/0 lan 10.10.10.0
Building configuration...
Current configuration : 5276 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
clock timezone PCTime 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
no ip bootp server
ip domain name yourdomain.com
ip name-server ip @ domain 1
ip name-server ip @ domain 2
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0/0
ip address 10.10.10.1 /24
ip access-group sdm_fastethernet0/0_in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1412
ip policy route-map lan0
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $ETH-LAN$
ip address IP @ A
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
pvc 8/35
oam-pvc manage
pppoe-client dial-pool-number 1
interface Serial0/2/0
ip address IP @ B
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/2/0
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list ACL_10 interface Dialer0 overload
ip access-list extended ACL_10
remark SDM_ACL Category=2
permit ip 10.10.10.0 0.0.0.255 any
ip access-list extended sdm_fastethernet0/0_in
remark SDM_ACL Category=1
permit ip any any
logging trap emergencies
access-list 120 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
route-map lan0 permit 10
match ip address 120
set ip next-hop ip@ of my ISP
control-plane
end
could you help me
thank's
kunalpurk
What i understanf from ur scenario is that ur outbound traffic towards the internet is taking the ADSL link as the primary and the ISDN link as the secondary link.Now , u want ur traffic coming from 10.0.0.0/24 network to always take the ADSL link to go outside and in case of any failure in the primary link, it would take the ISDN link.
Change ur route-map a bit :-
route-map lan0 permit 20
match ip address 130
access-list 130 permit ip any any
moreover, use 2 default routes ( one towards serial and one towrads dialer with a hiher AD value)
ip route 0.0.0.0 0.0.0.0 dialer0 10
Note: Remember the route-map always gets the priority over any other type of routes during the route lookup.
Hope this works out for u.Rate the post if it works or else get back with some further details.
kunalpurk
thank's for all this informations
it work's now the probleme was wen i use the next-hop ip addresse
i use the "set interface (adsl)"
thank's
Oscar Cardiel
Level 3
Level 3
Hi there,
I think that your route-map is wrong, it would be:
set interface dialer 0
Exactly that was the problem i put set ip interface (next hop)
when i made set interface it works
thank's for ur advice
thank's ALL
