Router Basics
nick050576
I apologise for the basic question, but I am just strating to try and learn some Cisco.
I am setting up a 1700 series router. Everytime I reload the router it starts up again with none of my config (I have done "copy running-config startup-config). I do a show startup-config and all my changes are there. Why doesnt it work in running config?
Thanks in Advance
Joe Clarke
Check the value of your config-register in show version. It should be 0x2102. If it is, for example, 0x2142, that would explain why the router is ignoring NVRAM when it boots.
Joe Clarke
Hi, It shows as 0x142...
How do I change this..
Sorted, changed it..
Thanks again
