Router not sending snmp traps
jclindsey
I am trying to figure out why my routers do not send traps to WhatsUp Gold.  All of my switches work properly, but the routers do not.  WUG is configured properly and each device has the right monitors enabled.  There are no ACLs on the management vlan that would block snmp. Most of the routers are 4500x models and the ones that aren't, we are in the process of replacing. As far as I can tell the model does not seem to matter.
Here is the snmp config that I am using.  It is the same as what I use on the switches. I realize I do not need the errdisable and port-security traps for the routers.
snmp-server community <communtiy> RW
snmp-server community <communtiy> RO
snmp-server contact <info>
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps port-security
snmp-server enable traps errdisable
snmp-server enable traps vlan-membership
snmp-server host <ip> version 2c <communtiy>
0 Replies 0
