router setting
ttroy.thomas1
Community Member
I need help getting into my router settings i have a dpc3925 cisco router and I tried looking up the username and password for my type of router but none of the work I need to get.into my router settings because my xbox is on the list of the that are blocked from using the internet and I am trying to unblock it​
Marvin Rhoads
If you don't have the username and password, you will have to reset the router and rebuild all its configuration from scratch. See the following links:
How to reset.
How to login.
