Routers and Switches Uptimes
ppl6
Does anyone know, what are the recomended uptimes for Cisco routers and switches? I believe the it depends on Model/Type.  After how long does a switch or a router needs to be rebooted? If possible, provide me with a list for all models or let me know where I could find this information.
Thank you
gajoshi
Hi Parul,
There's no as such recommended uptime as these equipments are quite robust, what you might consider is the memory utilization on the box from time to time and decide weather the unit needs a reload or not, a reload will free up all the unused memory.
You can run the following commands to check the current utilization:
sh mem summary
sh proc mem
(common for both switches and routers)
Thank you for your response Gaurav. I certainly will consider this
suggestion.
Take care
To: Parul Patel ,
Date: 01/27/2012 06:15 AM
Subject: - Re: Routers and Switches Uptimes
Home
created by Gaurav Joshi in Network Management - View the full discussion
Hi Parul,
