RTM File system usage on Solaris
I know this is a "it depends" question but need to ask just the same. How much file space does RTM need on a Solaris platform for the app and the db it builds. I know the majority of that will be in /OPT. Hopefully, the "estimate" is easier to figure than HPOV formulas.....
umedryk
Level 5
Level 5
As far as I know, there is no such theoritical limit on the file space required.
Supposedly, RTM on Solaris wants one 36Gb drive for the OS and a second 36Gb for nGenius and Sybase. How much of it does it actually uses depends on how many switch ports you want to monitor. I *think* the 36Gb drive is suppose to be big enough to support the maximum number of switch ports RTM can monitor.
