rv325
sam.rickett
I want to increase the maximum available number of IP addresses that DHCP can allocate, but when I try to go beyond .149 it comes up with an error saying that  "PPTP IP and SSL IP" range overlap.   We do not need either of these, but I cannot find where I can disable them so that I can extend the range
Mark Malone
Hi under the VPN tab there should be a pptp section make sure theres no range set in there , turn it off at enable button You should have a ssl tab too but I don't see that in your output maybe its in your vpn section too
Thanks, but it is impossible to disable that because if I remove the ranges it complains about that and if I leave the range in (but still have the enable checkbox unticked) it complains about that as well!
hmm looks like there maybe a firmware issue removing this .. see this
https://supportforums.cisco.com/discussion/12946911/rv325-firmware-v13110-how-disable-pptp-server
Thanks for that link, will try the JS debugger breakpoint hack.  The latest firmware is ~5 months old, does Cisco actively support this product?
