Campus Manager - Topology view problems
etmarcof
Level 3
Level 3
I have installed latest packages but in topology view:
- for a cat 3650 switch and an AP 350 i see a green cube with a question mark inside.
-and i can't see a fiber link between two cat 4507R.
Could someone help me,please?
Regards.
Mc
5 Replies 5
rmushtaq
Level 8
Level 8
What is the Campus Manager version?.
My switch is Cat 3560 not Cat 3650 (my mistake)
Campus Manager 3.3
In attach yo could see my versions:
Regards.
MC
kawng
Please check the Device Support list:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/camp_mgr/sup_dev/cm_3_3.htm
Please indicate what version you are running with which
IDU....
I don't see 3650s in the above link
Martin Ermel
Cat 3560 should be supported starting with IDU 7.0. IDU 10.0 is the actual one and is available for Campus Manger RME and DFM. If you have a login on Cisco`s web page with privileg for SW downloads you get the packages at:
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2425/index.html
MArtin
Thank you,it works now!
Regards.
MC
