sadiags.xml???
yjdabear
I just came across the above named file in $NMSROOT/bin on my PROD LMS server. It looks innocent enough, but I don't find any on my other PROD box or the TEST one. Just curious what it's for.
-rw------- 1 casuser casusers 1374 Jun 25 01:33
Lucien Avramov
Level 11
Level 11
It's a diagnostic file for database. I believe this is sybase related.
Would you know under what circumstances it gets produced (autonomously, I assume)? Also, it's curious it goes into bin, rather than say /var/adm/CSCOpx/log/.
This is not a logfile, hence it's not in the CSCOpx/log/ folder.
Its a file used to run diagnostics.
I believe the file is there since the install, it's for Sybase diagnostics. If db crashes happened, there will be crash files generated:
For example:
SA10_20080110_185142_5863.crash_log
-rw------- 1 root root 1941504 Jan 10 18:51 SA10_20080110_185142_5863.mini_core
I dont know how much LMS uses this at this point.
