Samsung DEX ..how to run packet tracer
I use Samsung DEX as my desktop. I want to run packet tracer.
marce1000
        - FYI : https://www.netacad.com/courses/packet-tracer/faq#6
 M.
Jitendra Kumar
On what platforms can I install and run Packet Tracer 8.1?
Cisco Packet Tracer 8.1 is compatible with the following platforms:
  • Microsoft Windows 8.1, 10, 11 (32 bit and 64bit)
  • Ubuntu 20.04 LTS (64bit)
  • macOS 10.14 or newer (64 bit)
What are the system requirements for Packet Tracer 8.1?
To successfully install and run Cisco Packet Tracer 8.1, the following system requirements must be met:
Cisco Packet Tracer 8.1 (64 bit):
  • Computer with one of the following operating systems: Microsoft Windows 8.1, 10, 11 (64bit), Ubuntu 20.04 LTS (64bit) or macOS 10.14 or newer.
  • amd64(x86-64) CPU
  • 4GB of free RAM
  • 1.4 GB of free disk space
Cisco Packet Tracer 8.1 (32 bit):
  • Computer with one of the following operating systems: Microsoft Windows 8.1, 10, 11 (32bit)
  • x86 compatible CPU
  • 2GB of free RAM
Jitendra
Jitendra
Hello,'
I don't think you can natively run Windows programs on Samsung Dex. Your best option might be to use something like Splashtop to remotely connect to your Windows PC from DEX,
https://www.youtube.com/watch?v=7NiCF5MVkY4
I was using dcloud to access packet tracer , but suddenly , I can't schedule sessions anymore. That solution worked great!
