Saving changes in CW2K
gabulldog7714
After pushing configs to various routers and AP's, I am unable to use the wr mem command. I get the error "Cannont find running-config". I am able to update a handful of routers but none of the AP's. I have the patch for 1200 series AP's but the firmware only supports up to 11.40. Any suggestions? Thanks in advance!
-Jonathan
steve.busby
Level 5
Level 5
Are the devices that are giving you problems managed by CW2K/RME? Look at CW2K>RME>Administration>Inventory>Import Status and see if any of these devices had attribute errors. Are they listed under the Managed devices?
If this looks good, go to Configuration Management>Archive Status and see if any of these devices are listed under Failed, Not Supported or Partial Failure. You should also verify they are listed under Successful.
If things look good, please let us know your server OS and CW2K component and patch versions.
