01-26-2005 08:07 AM
Customer has 130 3550 switches, 170 APs and 50 Routers (12.2T). They want to run a netconfig job to enable ssh everywhere. Can this be done? Is there a netconfig template for this? The key generation usually comes backs requesting input, etc.
NW-DC-RAS1(config)#crypto key generate rsa
The name for the keys will be: router1.local.lan
Choose the size of the key modulus in the range of 360 to 2048 for your
General Purpose Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]:
and sometimes the device already has a key (you don't see this via a show running-config)
% You already have RSA keys defined named NW-DC-RAS1.stellarishealth.net.
% Do you really want to replace them? [yes/no]:
01-26-2005 08:13 AM
I should clarify all devices are SSH capable, already have the correct K9 IOS loaded, it just needs to be turned on everywhere.
01-26-2005 12:25 PM
You don't mention your CW2K version or OS, but RME 3.5, IDU 9 on W2K, has a SSH Template for IOS devices.
It asks for Hostname/Domain Name/No. of Key Bits/SSH Timeout/No.of Authentication Retries
Unfortunately, it would appear all devices would have to have the same hostname. Unless you could wild-card it or somehow have it grab the existing hostname.
