Saving Running Config File for Cisco Stacked Switches
Johan Ling
For a stacked Cisco switch (2 switches), if I input the command copy running-config startup-config, will it save the running configuration file to the start-up config file for both switches?
I am thinking of rebooting the switches one at a time and want to make sure that the config file is the current configuration file after rebooting.
Thanks!
2 Accepted Solutions
johnd2310
Level 8
Level 8
Yes, config is saved to both switches in the stack. You can reboot the switches one at a time without a problem.
You can check by running the commands:
dir nvram:
dir stby-nvram:
John
**Please rate posts you find helpful**
Leo Laohoo
johnd2310
Level 8
Level 8
dir nvram:
dir stby-nvram:
John
Leo Laohoo
Should be fine.
