SCCP Unknown sessions
agup
We have a problem where the SCCP get stuck in 'UNKNOWN' / 'inactive' state. we run 'show sccp conn' command to check it manually. Looking for a script where we check for 'UNKNOWN' / 'inactive' sessions every hour, if there are 'n' number of sessions, then it would send out SNMP trap. Example output shown from 'sh sccp conn' command -
#sh sccp conn
sess_id    conn_id      stype mode     codec   sport rport ripaddr conn_id_tx
53645003   50656921     conf  inactive UNKNOWN 31106 0     UNKNOWN
53667104   50665149     conf  inactive UNKNOWN 16976 0     UNKNOWN
53671501   50666736     conf  inactive UNKNOWN 32456 0     UNKNOWN
Total number of active session(s) 3, and connection(s) 3
Thanks in advance...totally new to EEM scripting.....
Okay, then you can do this using an applet.
event manager applet sccp_watch
event timer watchdog time 3600
action 1.0 cli command "enable"
action 2.0 cli command "show sccp conn"
action 3.0 set i 0
action 4.0 foreach line $_cli_result "\n"
action 4.1  regexp UNKNOWN $line
action 4.2  if $_regexp_result eq 1
action 4.3   increment i 1
action 4.4  end
action 4.5 end
action 4.6 subtract $i 2
action 4.7 if $_result ge N
action 4.8  snmp-trap strdata "The number of UNKNOWN SCCP sessions is $_result"
action 4.9 end
6 Replies 6
Joe Clarke
What version of code is your router running?
IOS is 15.1.M4
action 3.0 set i 0
action 4.4  end
action 4.5 end
action 4.9 end
thanks Joseph, it works. The only difference I had to make was the following to match my requirements, thanks a lot to you and this forum.
action 3.0 set i 0
action 4.1  regexp inactive $line
action 4.4  end
action 4.5 end
action 4.6 if i ge N
action 4.7  snmp-trap strdata "The number of inactive SCCP sessions are $i"
action 4.8 end
I assume you also changed the 'N' in action 4.6 to the actual value of problem sessions, correct?
yes, that's right. N was changed to a value.
