Script Error Clearance Please
Hello Community,
I understand why I'm getting the following error on the router, but I don't know how to clear it.
I think the error is preventing any other scripts from being activated.
Aug 20 12:13:04.796: %HA_EM-7-FMS_POLICY_MAX_ENTRIES: fh_schedule_policy: Class default: Maximum number of 64 script publish entries exceeded; some events have been discarded
Can someone please show me how to clear it?
Cheers
Carlton
As I've said before, this message means you're receiving more events that you can service.  This could mean that you get so many matching syslog messages at one time that you cannot run enough concurrent policies to service them all.  Since by default, only one Tcl policy can run at a time, that would mean if you generate 66 matching syslogs at one time, the 66th message will be dropped out of the event queue.  You can play with the number of policies that can execute at once using the "event manager scheduler script thread class default number" command, but you have to be careful that you don't overwhelm the device.
9 Replies 9
Hi Community,
Can I get some help with this please?
Is there a way I can prevent this error message appearing?
Cheers
Community,
I don't know if the following is related to the above error, but when I do a debug of tcl I see the following:
fh_tty_read_cmd] read not ready
I'm not sure what that means
The thing I don't understand is that the error says
However, I only have 9 scripts, see below.
Any thoughts would be greatly appreciated.
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    script    user    timer watchdog      Off   Fri Aug 16 10:55:04 2013  stateInterfacestatus.tcl
name {stateInterfacestatus} time 60.000
nice 1 queue-priority low maxrun 20.000 scheduler rp_primary
2    script    user    timer watchdog      Off   Fri Aug 16 11:39:28 2013  utilisationHighInterfaceUt
ilization.
tcl
name {utilisationHighInterfaceU
tilizat} time 60.000
nice 1 queue-priority low maxrun 60.000 scheduler rp_primary
3    script    user    timer watchdog      Off   Fri Aug 16 13:14:10 2013  cpuHighCPUUsage.tcl
name {cpuHighCPUUsage} time 60.000
4    script    user    timer watchdog      Off   Fri Aug 16 13:16:09 2013  memoryHighMemory.tcl
name {memoryHighMemory} time 60.000
5    script    user    syslog              Off   Fri Aug 16 13:29:04 2013  configCONFCHG.tcl
occurs 1 pattern {SYS-5-CONFIG_I.*}
nice 0 queue-priority normal maxrun 20.000 scheduler rp_primary
6    script    user    syslog              Off   Fri Aug 16 17:29:09 2013  envAssetChassisIssue.tcl
severity-warning severity-minor severity-major severity-critical severity-fatal occurs 1 pattern {ENV.*}
nice 0 queue-priority normal maxrun 60.000 scheduler rp_primary
7    script    user    syslog              Off   Fri Aug 16 18:57:07 2013  syslogOSPF.tcl
priority all pattern {OSPF}
8    script    user    syslog              Off   Fri Aug 16 19:22:52 2013  syslogIPNAT.tcl
priority all pattern {IPNAT}
9    script    user    syslog              Off   Wed Aug 21 12:49:20 2013  syslogIOSVLAN.tcl
priority all pattern {SW_VLAN|VLAN|SW_VLAN_ISSU
|SPANTREE_
VLAN_SW|PL
ATFORM_VLA
N}
Cheers
Joseph,
I fully understand now. I didn't get it the first time.
Thanks again mate..
Cheers
Hi Joseph,
One last question regarding this issue:
Can you let me know how to prevent the syslog message from appearing:
Or better still, can you show me how to have the above syslog message appear only once in syslog messages?
Cheers
There is no one fix for this.  I told you one way to prevent it in my reply already.
Hi Joseph,
Thanks again for responding, if you mean the following;
Then this won't prevent the message from appearing in the syslog over and over....
It may help.  It's all about message rate, how long it takes the EEM policy to run, and how many threads you can get away with on your device.  You'll have to test to find the right balance.  And if the rate of messages is still too high, you'll have to reconsider your policy design.
