Scrolling up on a Cisco sh run
rockcallahan68
Hi, I am wondering if anyone can offer some advice on how to scroll up on a cisco sh run (ssh from putty).
An example is if I am checking BGP peers by name and I am looking to get the IP, I can do sh run then /peername. This will bring me to the line underneath the one which lists the IP, but anything I click at this point either scrolls down, exits the sh run, or just scrolls up my actual terminal past the bit where I requested the sh run (rather than scrolling within the sh run). I know I can get this info in other ways, but the lack of being able to scroll up is really frustrating. Am I missing something, is this putty weirdness, or did Cisco just not add the ability to scroll up?
Thank you
Mark Elsen
  - At least Cisco does not offer support for it , possibilities will depend on the terminal software type being used ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
can you post a screenshot ?
Hello @rockcallahan68 ,
putty is not one of the best terminal software out there. I remember using it in the past and having similar problems like you describe. I moved to SecureCRT.
Regards, LG
*** Please Rate All Helpful Responses ***
