SDM does not run
dtom
Level 6
Level 6
I am trying to run SDM on my XP Workstation. The following is installed:
SDM 2.5
Java 1.6.0_06-b02
When I launch SDM I get the following:
Browser: IE 7.0
Java: Enabled
Then I get a popup window with a bunch of Java code:
(partial copy of code)
* runAPP.shtml
* Copyright (c) 2004 by Cisco Systems, Inc. All rights reserved.
<HTML>
<HEAD>
<script language="javascript" src="common.js"></script>
<script language="javascript" src="appsupport.js"></script>
<script language="javascript" src="localized_msgs6.js"></script>
<script language="javascript">
function getcookie(cookiename) {
var cookiestring=""+document.cookie;
var index1=cookiestring.indexOf(cookiename)
if (index1==-1 || cookiename=="") {
return "";
var index2=cookiestring.indexOf(';',index1);
if (index2==-1) index2=cookiestring.length;
var c = unescape(cookiestring.substring(index1+cookiename.length+1,index2));
return c;
} // getcookie()
function cookieLifeTime() {
var UTCstring;
Today = new Date();
nomilli=Date.parse(Today);
Today.setTime(nomilli+365*24*60*60*1000);
UTCstring = Today.toUTCString();
return UTCstring;
} // cookieLifeTime()
function setcookie(name, value) {
cookiestring=name+"="+value+";EXPIRES="+cookieLifeTime()+";path=/";
document.cookie=cookiestring;
return getcookie(name);
} // setcookie()
function docRoot() {
var args = location.search;
if (args && args.indexOf("SDMONPC=") != -1) {
var curLoc = location.protocol + "//" + location.host + location.pathname;
var i = curLoc.lastIndexOf('/');
var j = curLoc.lastIndexOf('\\');
if ((i == -1) || (i < j)) i = j;
var curBase = unescape(curLoc.substring(0, i));
i = curBase.lastIndexOf('/');
j = curBase.lastIndexOf('\\');
var curBase = curBase.substring(0, i);
curBase = curBase.substring(0, i + 1);
return curBase;
What do I need to do?
sirdudesly
Level 5
Level 5
I think that if you just tap f5 that window will refresh and give you the security prompt, confirm it and off you go.
CmdLineHell
Community Member
If you're using IE, on its toolbar go to Tools->Options. Select the Advanced Tab. Scroll down to Security. Check "Allow active content to run in files on My Computer". Close IE and start again.
