Send Syslog Question
PolarPanda
Level 4
Level 4
Hi there,
          I want to setup send syslog from a router(public ip) to SNMP server(private ip). I've successful setup sending syslog from another router(private ip) to snmp server(private ip). Do I need to do special configuration on firewall or router? Thank you.
Mark Elsen
 - The destination (syslog)-host must be reachable from the source, no matter what.
    M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
IF the Public required to Send Logs to Private IP, you need reachability (like you need static NAT from Public IP to Private IP on the outside of Router/ FW to get work.
Like this
Device(publicIP) ------publicip(Router/FW)----pricate IP (syslogServer)
BB
