Sending cfg via SNMP not working
ppucci
I am trying to send some configs using SNMP to a 7200 (using 12.4(21a)) and it fails me on the last command when trying to start the procedure, as follows:
persio.pucci@tacacs:/tftpboot$snmpset -v2c -c COMUNITY 10.20.30.1 .1.3.6.1.4.1.9.9.96.1.1.1.1.2.200 integer 1
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.2.200 = INTEGER: 1
persio.pucci@tacacs:/tftpboot$ snmpset -v2c -c COMUNITY 10.20.30.1 .1.3.6.1.4.1.9.9.96.1.1.1.1.3.200 integer 1
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.3.200 = INTEGER: 1
persio.pucci@tacacs:/tftpboot$ snmpset -v2c -c COMUNITY 10.20.30.1 .1.3.6.1.4.1.9.9.96.1.1.1.1.4.200 integer 4
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.4.200 = INTEGER: 4
persio.pucci@tacacs:/tftpboot$ snmpset -v2c -c COMUNITY 10.20.30.1 .1.3.6.1.4.1.9.9.96.1.1.1.1.5.200 address 10.10.10.1
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.5.200 = IpAddress: 10.10.10.1
persio.pucci@tacacs:/tftpboot$ snmpset -v2c -c COMUNITY 10.20.30.1 .1.3.6.1.4.1.9.9.96.1.1.1.1.6.200 string user
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.6.200 = STRING: "user"
persio.pucci@tacacs:/tftpboot$ snmpset -v2c -c COMUNITY 10.20.30.1 .1.3.6.1.4.1.9.9.96.1.1.1.1.14.200 integer 4
Error in packet.
Reason: inconsistentValue (The set value is illegal or unsupported in some way)
Failed object: SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.14.200
I can see that the entry was created, but I cannot issue a "CreateAndGo" command.
persio.pucci@tacacs:/tftpboot$ snmpwalk -v2c -c COMUNITY 10.20.30.1 .1.3.6.1.4.1.9.9.96.1.1.1.1
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.9.200 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.10.200 = INTEGER: 4
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.11.200 = Timeticks: (1836298009) 212 days, 12:49:40.09
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.12.200 = Timeticks: (1836302109) 212 days, 12:50:21.09
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.13.200 = INTEGER: 3
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.14.200 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.15.200 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.16.200 = STRING: "10.10.10.1"
Any ideas?
ccube
First, make sure the contextual row number you're going to use is destroyed, then do your snmpset as a single snmpset command instead of setting individually for your create and go row.
Snmpset -v2c - c com string device snmpvar1 snmpvar2
And so on...
Something like this:
You need to create the row. Then you would go about setting the various
objects of the row
-protocol for transfer
-ipAddress of the server
-file names for Dst and Src
and then, finally activate the row.
Example using OIDs - You must enter the enter row sequence as follows:
snmpset -v 1 -c private 10.44.31.194 .1.3.6.1.4.1.9.9.96.1.1.1.1.2.90 i
1 .1.3.6.1.4.1.9.9.96.1.1.1.1.3.90 i 4 .1.3.6.1.4.1.9.9.96.1.1.1.1.4.90
i 1 .1.3.6.1.4.1.9.9.96.1.1.1.1.5.90 a 10.44.31.134
.1.3.6.1.4.1.9.9.96.1.1.1.1.6.90 s router-config
.1.3.6.1.4.1.9.9.96.1.1.1.1.14.90 i 4
Example using NAMED OIDs:
snmpset -v 1 -c private 10.44.31.194 ccCopyProtocol.90 integer 1 ccCopySourceFileType.90
integer 1 ccCopyDestFileType.90 integer 3
ccCopyServerAddress.90 ipaddress "10.44.31.134" ccCopyFileName.90 octetstring
"router-config" ccCopyEntryRowStatus.90 integer 4* *
Both of the above example are entered contiuously as one line.
Hth,
Cary
