Sending email with eem script
mialbert
I have an eem script that i want to alert on a syslog event and then send an email.  The script is:
event manager applet syslog-alert
event syslog pattern “.*%IDS-6-.*”
action 1.0 mail server "192.168.1.2" to "xuser1@domain.com" from "xuser2@domain.com" subject "IDS Alert"
action 1.1 syslog msg "IDS alert has been sent to email server!"
I get the below error when ran:
*Apr 6 15:38:27.222 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : smtp_connect connect fail 260
*Apr 6 15:38:27.222 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : fh_smtp_connect callback timer is awake
*Apr 6 15:38:27.222 CST: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 192.168.1.2 : timeout error
*Apr 6 15:38:27.694 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : smtp_connect connect fail 260
*Apr 6 15:38:27.694 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : fh_smtp_connect callback timer is awake
*Apr 6 15:38:27.694 CST: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 192.168.1.2 : timeout error
*Apr 6 15:38:28.838 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : smtp_connect connect fail 260
*Apr 6 15:38:28.838 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : fh_smtp_connect callback timer is awake
*Apr 6 15:38:28.838 CST: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 192.168.1.2 : timeout error
*Apr 6 15:38:29.142 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : smtp_connect connect fail 260
*Apr 6 15:38:29.142 CST: %HA_EM-6-LOG: ids-alert : DEBUG(smtp_lib) : fh_smtp_connect callback timer is awake
*Apr 6 15:38:29.142 CST: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 192.168.1.2 : timeout error
Can this be done to a mail server that requires authentication?  Or do i have to have one that doesn't do authentication?
aydinnmu1
eem doesn't support authentication parameters. You should select no authentication on server side.
or
you can write TLC script like this answer.
https://supportforums.cisco.com/discussion/11070866/eem-cisco-877-trouble-mail-server-action-and-smtp-auth
