Serial down message timers
rmweaver
Community Member
              I have a router that has a 3G backup VPN, and am trying to setup it to send a text when the primary circuit fails.
I realize it has some shortcomings in that it doesn't check if the cell connection is up or anything. But want I'm looking for is a way to avoid the situation of a million text messages if the primary connection is flapping. I see there are a number of timers, I'm not sure which is most appropriate. Is there a way for it to only send the message say no more than every 30 minutes?
Thanks in advance for the help
Here is my current script.
event manager applet track_Serial_down
event track 1 state down
action 1 syslog msg "EEM applet track_Serial_down sending messag"
action 2 cli command "enable"
action 3 cli command "cellular 0/1/0 cdma sms send xxxxxx 'text message down'"
event manager applet track_Serial_up
event track 1 state up
action 1 syslog msg "EEM applet track_Serial_up Sending message"
action 3 cli command "cellular 0/1/0 cdma sms send xxxxxxxx 'tex message up'"
end
6 Replies 6
Joe Clarke
You could have the down applet reconfigure itself so the event is none.  Then have it reconfigure a third applet to rearm it after a certain amount of time.  The same could be done for the up applet:
action 3.1 cli command "config t"
action 3.2 cli command "event manager applet track_Serial_down"
action 3.3 cli command "event none"
action 3.4 cli command "event manager applet timer_down"
action 3.5 cli command "event timer countdown time 1800"
action 3.6 cli command "end"
action 3.2 cli command "event manager applet track_Serial_up"
action 3.4 cli command "event manager applet timer_up"
event none
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "event manager applet track_Serial_down"
action 4.0 cli command "event track 1 state down"
action 5.0 cli command "event manager applet timer_down"
action 6.0 cli command "event none"
action 7.0 cli command "end"
event none
action 3.0 cli command "event manager applet track_Serial_up"
action 4.0 cli command "event track 1 state up"
action 5.0 cli command "event manager applet timer_up"
Thanks for the help Joesph. I set it up as below.(which I think is right). What happened was the message events would fire once. The parts of the script that set the countdown time would not set. lines 3.6 and 3.7. I inserted the end and config t to see if that made difference it didn't. In the debug it puts out a message for the line 3.6 but nothing for 3.7. Not sure if it is running it or not.
action 3 cli command "cellular 0/1/0 cdma sms send 111111111 'message'"
action 3.4 cli command "end"
action 3.5 cli command "config t"
action 3.6 cli command "event manager applet timer_down"
action 3.7 cli command "event timer countdown time 300"
action 3.8 cli command "end"
action 3 cli command "cellular 0/1/0 cdma sms send 1111111111 'message'"
action 3.6 cli command "event manager applet timer_up"
event none
event none
Can you post the debug output from "debug event manager action cli" showing one of the track applets running?
Before
action 3 cli command "cellular 0/1/0 cdma sms send 1111111111 'Site  MPLS Down on Cell modem'"
action 3 cli command "cellular 0/1/0 cdma sms send 1111111111 'Site  back on MPLS'"
event none
event none
after
scheduler allocate 20000 1000
ntp server 10.32.161.245 prefer
event none
event none
event none
end
debug
router#
router#
router#
Oct 25 11:58:27.851: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to
administratively down
Oct 25 11:58:28.787: %TRACKING-5-STATE: 1 interface Se0/0/0:0 line-protocol Up->
Down
Oct 25 11:58:28.787: %HA_EM-6-LOG: track_Serial_down: EEM applet track_Serial_do
wn sending messag
Oct 25 11:58:28.787: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : CTL :
cli_open called.
Oct 25 11:58:28.795: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : OUT :
! WARNING: All changes are logged and must be cleared through    !
! Network Engineering Services and Change Authorization Board.  !
! Failure to do so can result in immediate termination.          !
router>
Oct 25 11:58:28.795: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : IN  :
router>enable
Oct 25 11:58:28.807: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : OUT :
router#
Oct 25 11:58:28.807: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : IN  :
router#cellular 0/1/0 cdma sms send 1111111111 'Site MPL
Oct 25 11:58:28.967: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : OUT :
router#
Oct 25 11:58:28.967: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : IN  :
router#config t
Oct 25 11:58:28.979: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : OUT :
Enter configuration commands, one per line.  End with CNTL/Z.
router(config)#
Oct 25 11:58:28.979: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : IN  :
router(config)#event manager applet track_Serial_down
Oct 25 11:58:28.991: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : OUT :
router(config-applet)#
Oct 25 11:58:28.991: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : IN  :
router(config-applet)#event none
Oct 25 11:58:29.003: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : OUT :
Oct 25 11:58:29.003: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : IN  :
router(config-applet)#event manager applet timer_down
Oct 25 11:58:29.015: %HA_EM-6-LOG: track_Serial_down : DEBUG(cli_lib) : : CTL :
cli_close called.
Oct 25 11:58:29.015: tty is now going through its death sequence
Oct 25 11:58:29.847: %LINK-3-UPDOWN: Interface Serial0/0/0:0, changed state to d
own
Oct 25 11:58:30.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0
:0, changed state to down
Oct 25 11:58:31.123: %CELLWAN-2-SMS_ARCH_PATH_UNCONFIGURED: Cellular0/1/0 failed
to archive SMS because 'gsm|cdma sms archive path' under cellular controller is
not configured.
Oct 25 11:58:31.123: %CELLWAN-5-OUTGOING_SMS_SENT: Cellular0/1/0 has just sent a
n outgoing SMS successfully.
router#
Oct 25 11:59:18.591: %SYS-5-CONFIG_I: Configured from console by vty0 (10.36.180.1)
router#show clock
11:59:34.687 UTC Fri Oct 25 2013
router#show clock
12:00:54.551 UTC Fri Oct 25 2013
router#show clock
12:01:44.095 UTC Fri Oct 25 2013
router#show clock
12:03:34.003 UTC Fri Oct 25 2013
router#sh run
Reverse the actions so that you reconfigure the other applet first:
action 3.2 cli command "event manager applet timer_up"
action 3.3 cli command "event timer countdown time 300"
action 3.6 cli command "event manager applet track_Serial_up"
action 3.7 cli command "event none"
Follow this same approach for the other applets, too.
That did the trick. Thanks a million for the help.
I'm wondering if using an  IPSLA to generate the message would be cleaner. The issue I noticed is after circuits flapping the last message sent doesn't reflect the state of the circuit. like for example if it goes down up down (within the timer) then the second down message won't be sent, (which is by design i know), but I can see that as a problem in that the people getting the message won't know the status.
Maybe using an IPSLA to check if the circuit is up would be cleaner. I'll check that out.. and come back if I can't figure it out.
