Serial number reporting in Hardware inventory
tverhoeven
I have recently updated everything in CiscoWorks to 2.6. RME 4.0.5.
I run the hardware inventory and there are several switches that have not serial number reporting. 2900 and 2950 mostly. Some of the serials report but most do not. I have verified that they are all on the same IOS and none of them have the snmp-server chassis-id command in them.
Any thoughts???
Kiwi reports everything fine
David Stanford
Can you manually poll the serial number via snmp to see if it returns the correct results?
Yes Sir!!! Works no problem.
I used the Ciscoworks to do a SNMP Walk and found the serial number in the switch.
I deleted the switch (or at least I think I did) from the database and added it again. No change....
