Serial Numbers LMS Infrastructure ACS
steve switzer
Does anyone know where to find the serial nos for ....
Prime LMS
Prime Infrastructure
ACS
If so can you let me know
Steve
AFROJ AHMAD
HI Steve,
The serial number (PIN/PAK) should be on the box in which LMS was shipped.  It is not recorded electronically within LMS.
or
look inside the license file  .lic
-the PAK is the serial
check the below link too:
https://supportforums.cisco.com/message/3510700#3510700
For prime infrastructure :
Go to ADMIN > licensing
For ACS , I need to look
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
For ACS:
Cisco usually locate the serial number in at least one of
the following places:
1-On the chassis it self
2-On label on the box the appliance shipped in from Cisco
3-You can locate it through one of outputs from the device (in The ACS SE
situation S/N do not exist in outputs commands)
4-You can found it on the sales order of this appliance (contact your
network administrator regarding that)
Thanks-
Afroz
