Server hardware for Cisco Works LMS 3.x
I have a Cisco Works LMS 2.6 installed on an IBM server with 2 Intel XEON 3,20Ghz and 3Gb RAM.
Now I am going to upgrade it to LMS 3.x with support for 1.5k devices.
On data sheet this product is associated with a server with 2 Intel XEON 3,66Ghz and 4Gb RAM.
Is this server's configuration recomended or necessary?
Thanks in advance
Antonio
Joe Clarke
Assuming you plan to install all applications on a single server, then this server exactly meets the hardware requirements for LMS 3.0.
