server system requirement LMS3.0
ttrinh73349
I'm planning to install LMS 3.0/3.01 on VMware ESX 3.0. The documentation does not specify the minimum requirement with less than 1500 devices . Is this the minimum requirement specification?
Intel Xeon with 2 CPU at 3.66Ghz and 4GB RAM memory and 8 GB swap space.
80GB Disk Space.
thanks,
Joe Clarke
It depends on the number of devices you are planning to manage, and the apps you plan to install from the LMS bundle.
800-1000 devices for now. Install all LMS 3.0 bundles.
The VM must have at least 4 GB of RAM and 8 GB of swap with access to at least two CPU cores. The physical machine must have at least this hardware.
