Setting up netflow on Nexus 7K - ver 6.1(3)
sdavids5670
Level 2
Level 2
I was trying to get Netflow setup on one of my 7K VDCs and ran into a problem.  While netflow data was reaching the collector, IP src/dst information was not appearing in the analyzer tool.  I could not see any information about conversations.  So I contacted the company that makes the collector/analyzer and the directed me to a blog on their site and told me to setup the 7K exactly as it is described in the blog post.  I did and a bit later the ip src/dst address information appeared.  So the only difference between the two configurations was that in the first case I tried to define a record and in the second case, no record was defined and instead the orginial-netflow parementer was used in the "flow monitor" section.
Here's the original config (that didn't work):
feature netflow
flow timeout active 60
flow exporter NETFLOW-COLLECTOR
  destination 172.19.30.136 use-vrf management
  transport udp 9996
  source mgmt0
  version 9
flow record Default-Netflow-Record
  match ipv4 source address
  collect counter bytes long
  collect counter packets long
flow monitor My-Flow-Monitor
interface Vlan3049
  (partial-config)
  ip flow monitor My-Flow-Monitor input
And here is the config (that does work):
feature netflow
flow exporter NFAexporter
  transport udp 9996
  source mgmt0
  version 9
flow monitor NFAmonitor
  record netflow-original
  ip flow monitor NFAmonitor input
interface Vlan3049
  (partial config)
I referenced the document "Cisco Nexus 7000 Series NX-OS System Management Configuration Guide,Release 6.x", Chapter 19 - Configuring NetFlow.
It's clear to me that I didn't do something right in defining my own record since that's really the only difference between the config that worked vs the config that didn't.  However, the documentation I referenced doesn't really provide helpful information about how to create a record (above and beyond what I can already see by typing '?' at the CLI).  For example, the "match" command makes no sense to me.  Usually when you have a match command it is accompanied by some sort of ACL.  In the "flow record" section a match command would be something like "match ipv4 source address" but that's it.  What does that mean?  Match anything that has a IPv4 source address??  That doesn't make much sense.  The collect commands are equally as bewildering.  If I want to define my own record (and not use the original-netflow parameter) what do I need to do in the "flow record" sub-configuration to get Nexus to send ip src/dst information to the collector (which, I would think, is basic information to send - what good is netflow data without it)?
Steven
jakewilson
HI Steven,
I found a link on Cisco's site in a google search:Nexus 7000 NetFlow NX OS configuration
This other blog post on Nexus 7000 NetFlow might help with the question "how to create a record" as your match and collect statements look a little thin to me.  There is a good blog on how match and collect work.
Please vote on my post if this information helps.
Sincerely,
Jake - NetFlow Knight
luioskaung90
Hello Steven,
Have you already resolve this issue ?
if you are using vrf management IP but you trying to get data from different vrf. is it possible to get the data ?
