SG300 Multiple DHCP forwarders for VLANs
Bjorn Dirchsen
Hi Guys,
I'm setting up a network where I have 2 VLANS (VLAN20 and VLAN30) from a main Cisco switch, trunk'ed to an SG300-10PP switch (in L3 mode).
I have managed to configure a DHCP relay for VLAN30 using DHCP server 10.10.0.1. But I need to configure another DHCP server for a different VLAN - VLAN20 - using DHCP server 192.168.1.1.
Ports 1-4 should be assigned to VLAN20 and port 5-8 to VLAN30. The assignment (or join) is not the problem, but I cannot see how i can "link" a DHCP server to each VLAN.
I can add a number of DHCP servers in the settings, but how does the swich know which DHCP server to choose?
DHCP Relay Server TableDHCP Server IP Address
10.10.0.1
192.168.1.1
Am I missing something? (very likely ;))
Best regards,
Bjorn Dirchsen
pieterh
you cannot link a dhcp server to a vlan! (dhcp=layer-3, vlan=layer-2)
you can assign an SVI/VIP (virtual interface IP address) to a vlan and assign a DHCP relay for this interface
if the DCHP server is the SG300 itself, then you do not need a DHCP relay,
just configure a SVI/VIP and the DHCP scope of course, the SVI/VIP and scope are matched by the subnet used
so you need to a configure an IP-address for each vlan where you need DHCP or DHCP-relay
pieterh
Thanks a lot @pieterh. I followed your suggestion and now I have two nice VLANs on completely different subnets with IP addresses being served from the firewall.
Best regards,
Bjorn Dirchsen
pieterh
good to hear you made it work
and thank you for marking my answer as solution
Best Regards,
Pieter
