12-05-2012 06:29 AM
It is possible through EEM/TCL Scripting, to apply different policies for traffic shaping for certain periods of time?
Having for example an Internet connection of 100Mb, when the LAN interface is achieving 100Mb, apply a policy permitting shaping plus 5% bandwidth in WAN connection for 5 minutes and then returning to the policy initially limited to 100Mb.
Something like this:
policy-map Shapping_100Mb
class class-default
shape average 100000000
policy-map Shapping_105Mb
class class-default
shape average 105000000
When the LAN interface hasn´t reached 100Mb, apply the Shapping_100Mb policy on the WAN interface.
When the LAN interface has reached 100 Mb, apply the Shapping_105Mb policy on the WAN interface for 5 minutes, and then return to the previous policy.
Is this possible?
Thanks in advance.
Best Regards
12-06-2012 07:01 AM
Simlpy - yes, but you will have to do some realy digging for the actual settings.
You will have to monitor the interface TX & RX packets in a specific time period and I suspect convert them to value you are checking for in the script. Once the condition is met - a simple config change of applying the policy to the interface.
the same would be said to remove it - I have seen something like this done before, I suggest you use your favorite search engine and start searching......
HTH>
12-07-2012 02:00 AM
Ok, thanks Andrew.
