show clock with EEM
junsung kim
Hi, everyone
I want to show "show clock" on the screen when i enter show command using EEM script.
but i don't know how to do it
could you give me a guide?
thank you
best regards
balaji.bandi
Not able to understand the requirement here - can you please explain more what you trying to achieve.
BB
Hi balaji,
For example, when i input "show ip int brief" command, before the result is shown,
the result of "show clock" should be shown first or at the end.
So, i want to see when i input every show command
thank you for your kindness
Why not have an AAA system in place so you can log all the information to the AAA system which has all the information you looking for.
EEM is for a different purpose than what you looking to do. you can also log using EEM script, but the user can clear Syslog messages.
example :
tacacs-server host x.x.x.x key xxxxx   <<-- change xxx as per the requirement
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
Nov 22 01:45:12 Y.Y.Y.Y  %xxxx5-514008: User 'BBANDI' executed the 'write memory' command.
BB
