show ip cache flow
jdleon
Community Member
How can the command "show ip cache flow" help me troubleshoot network traffic problem, especially pinpointing a node hogging the bandwidth? Is there another command(s) I can also use?
garapoglou
Level 7
Level 7
Since you have configured Netflow, you should enable Netflow top-talkers too. This will provide information about the nodes consuming the most bandwidth, depending on the settings you've chosen.
http://www.cisco.com/en/US/docs/ios/netflow/configuration/guide/cfg_nflow_top_talk.pdf
Best regards,
Giorgos
