SIP incoming calls to ISDN outgoing calls CUBE CISCO 2911 E1 Problem
fraga
Hello, everyone !
I'm having problems with a SIP incoming calls.
The infrastructure in place has the outgoing call-leg a controller E1 running ISDN protocol as below:
PABX ----(isdn)----- CISCO 2911----(sip)----- SIP Server
Cisco 2911 IP address for incoming SIP calls: 10.26.2.2
SIP Server IP address: 10.166.4.1
Calls started by the PABX towards the SIP Server are OK
but calls in the opposite direction are stopping in CISCO 2911 with the following debug output:
Sep 14 15:33:09.292: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:8334336@10.26.2.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.166.4.1:5062;rport;branch=z9hG4bK78ry9D0tppBpD
Max-Forwards: 70
To: <sip:8334336@10.26.2.2:5060>
Call-ID: 52bde062-32d6-1237-409b-005056ae08a8
CSeq: 937825559 INVITE
Contact: <sip:8306640@10.166.4.1:5062;transport=udp>
User-Agent: SipGateway-V2-sofia sofia-sip/1.12.11
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, PRACK, MESSAGE, SUBSCRIBE, NOTIFY, REFER, UPDATE, INFO, PUBLISH
Supported: timer, 100rel
Allow-Events: presence
Session-Expires: 120;refresher=uac
Min-SE: 120
Content-Length: 0
Sep 14 15:33:09.292: //-1/51489B678092/SIP/State/sipSPIChangeState: 0x3EA52048 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Sep 14 15:33:09.292: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
Sep 14 15:33:09.292: //-1/51489B678092/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Sep 14 15:33:09.292: //-1/51489B678092/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:422, container:3EB9DBA0
Sep 14 15:33:09.292: //-1/51489B678092/SIP/State/sipSPIChangeState: 0x3EA52048 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
Sep 14 15:33:09.296: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 422 Session Timer too small
To: <sip:8334336@10.26.2.2:5060>;tag=2437CFC-2350
Date: Fri, 14 Sep 2018 15:33:09 GMT
Allow-Events: telephone-event
Min-SE: 1800
Server: Cisco-SIPGateway/IOS-15.3.3.M5
Content-Length: 0
Sep 14 15:33:09.792: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Min-SE: 120
Content-Length: 0
Sep 14 15:33:09.792: //-1/51489B678092/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Sep 14 15:33:09.792: //-1/51489B678092/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:422, container:3EB9DD58
Sent:
Min-SE: 1800
Content-Length: 0
Sep 14 15:33:09.796: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
Content-Length: 0
Sep 14 15:33:12.792: //-1/51489B678092/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Sep 14 15:33:12.792: //-1/51489B678092/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:422, container:3EB9D518
Sep 14 15:33:12.792: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 14 Sep 2018 15:33:12 GMT
Min-SE: 1800
Content-Length: 0
Sep 14 15:33:28.797: //-1/51489B678092/SIP/Error/act_disconnecting_wait_ack:
Out of retries
Sep 14 15:33:28.797: //-1/51489B678092/SIP/State/sipSPIChangeState: 0x3EA52048 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
Sep 14 15:33:28.797: //-1/51489B678092/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x3EA52048
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 8306640
Called Number : 8334336
Source IP Address (Sig ): 10.26.2.2
Destn SIP Req Addr:Port : 10.166.4.1:0
Destn SIP Resp Addr:Port : 10.166.4.1:5062
Destination Name : 10.166.4.1
Disconnect Cause (CC) : 100
Disconnect Cause (SIP) : 422
I know the cause SIP/2.0 422 Session Timer too small means some problem related to the
min-se timer but I tried to modify the default value from 1800 to 3600 and even greater but the problem persists.
I also tried to modify the value to 120 (as suggested in the above debug output) and, in this case, I had another debug output:
Sep 14 15:47:44.275: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.166.4.1:5062;rport;branch=z9hG4bKK2Z2KUDp3249Q
Max-Forwards: 70
Call-ID: 5c1ed620-32d8-1237-409b-005056ae08a8
CSeq: 937826419 INVITE
Min-SE: 120
Content-Length: 0
Sep 14 15:47:44.275: //-1/5AD06168809A/SIP/State/sipSPIChangeState: 0x3EA4BA40 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Sep 14 15:47:44.275: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Sep 14 15:47:44.275: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Sep 14 15:47:44.275: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:3EB9D518
Sep 14 15:47:44.275: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:120, SE Refresher:uac, Min-SE Value:120, flags:2001
Sep 14 15:47:44.275: //-1/xxxxxxxxxxxx/SIP/Error/sipSPICheckAnatGroupPresent:
NULL sdp
Sep 14 15:47:44.275: //-1/5AD06168809A/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=8306640
----- ccCallInfo IE subfields -----
cisco-ani=8306640
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=8334336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Sep 14 15:47:44.279: //-1/5AD06168809A/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3D28D214, Call Info(
Calling Number=8306640,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=8334336(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11
Sep 14 15:47:44.279: //-1/5AD06168809A/CCAPI/ccCheckClipClir:
In: Calling Number=8306640(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=8306640(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Sep 14 15:47:44.279: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 14 15:47:44.279: :cc_get_feature_vsa malloc success
Sep 14 15:47:44.279: cc_get_feature_vsa count is 1
Sep 14 15:47:44.279: :FEATURE_VSA attributes are: feature_name:0,feature_time:591102296,feature_id:11
Sep 14 15:47:44.279: //11/5AD06168809A/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=8306640(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=8334336(TON=Unknown, NPI=Unknown))
Sep 14 15:47:44.279: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Sep 14 15:47:44.279: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:3EB9D9E8
Sep 14 15:47:44.279: //11/5AD06168809A/SIP/State/sipSPIChangeState: 0x3EA4BA40 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_RECD_INVITE, SUBSTATE_NONE)
Sep 14 15:47:44.279: //11/5AD06168809A/CCAPI/cc_process_call_setup_ind:
Event=0x3D5042B8
Sep 14 15:47:44.279: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 8334336
Sep 14 15:47:44.279: //11/5AD06168809A/CCAPI/ccCallSetContext:
Context=0x23B2C4D4
>>>>CCAPI handed cid 11 with tag 1 to app "_ManagedAppProcess_Default"
Sep 14 15:47:44.279: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Fri, 14 Sep 2018 15:47:44 GMT
Content-Length: 0
Sep 14 15:47:44.279: //11/5AD06168809A/CCAPI/ccCallProceeding:
Sep 14 15:47:44.279: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Sep 14 15:47:44.283: //11/5AD06168809A/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=1000, Params=0x23B2DA94, Progress Indication=NULL(0)
Sep 14 15:47:44.283: //11/5AD06168809A/CCAPI/ccCheckClipClir:
Destination Pattern=8334[034].., Called Number=8334336, Digit Strip=TRUE
Redirect Number=, Display Info=
Account Number=8306640, Final Destination Flag=TRUE,
Guid=5AD06168-B76C-11E8-809A-83FE496797BE, Outgoing Dial-peer=1000
Sep 14 15:47:44.283: //11/5AD06168809A/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=8306640
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=8334336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 14 15:47:44.283: //11/5AD06168809A/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3EB9F6C8, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=8306640,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=8334336(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1000, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sep 14 15:47:44.283: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 14 15:47:44.283: :cc_get_feature_vsa malloc success
Sep 14 15:47:44.283: cc_get_feature_vsa count is 2
Sep 14 15:47:44.283: :FEATURE_VSA attributes are: feature_name:0,feature_time:591102072,feature_id:12
Sep 14 15:47:44.283: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Sep 14 15:47:44.283: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Sep 14 15:47:44.283: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_early_dialog_container
Sep 14 15:47:44.283: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Sep 14 15:47:44.283: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Sep 14 15:47:44.283: //12/5AD06168809A/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Sep 14 15:47:44.283: //12/5AD06168809A/CCAPI/ccCallSetContext:
Context=0x23B2DA44
Sep 14 15:47:44.283: //11/5AD06168809A/CCAPI/ccSaveDialpeerTag:
Sep 14 15:47:44.431: //12/5AD06168809A/CCAPI/cc_api_call_proceeding:
Interface=0x3EB9F6C8, Progress Indication=NULL(0)
Sep 14 15:47:44.479: //12/5AD06168809A/CCAPI/cc_api_call_alert:
Interface=0x3EB9F6C8, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
Sep 14 15:47:44.479: //11/5AD06168809A/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Sep 14 15:47:44.479: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Sep 14 15:47:44.479: //11/5AD06168809A/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0xB, gcid=5AD06168-B76C11E8-809D83FE-496797BE, tag=0x0)
Sep 14 15:47:44.479: //12/5AD06168809A/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0xC, gcid=5AD06168-B76C11E8-809D83FE-496797BE, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=11, Call Id2=12, Tag=0x0
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_CALL_BRIDGE
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Sep 14 15:47:44.483: //11/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 14 15:47:44.483: cc_api_get_xcode_stream : 4936
Sep 14 15:47:44.483: //11/5AD06168809A/CCAPI/cc_api_bridge_done:
Conference Id=0x3, Source Interface=0x3D28D214, Source Call Id=11,
Destination Call Id=12, Disposition=0x0, Tag=0x0
Sep 14 15:47:44.483: //12/5AD06168809A/CCAPI/cc_api_bridge_done:
Conference Id=0x3, Source Interface=0x3EB9F6C8, Source Call Id=12,
Destination Call Id=11, Disposition=0x0, Tag=0xFFFFFFFF
Sep 14 15:47:44.483: //11/5AD06168809A/CCAPI/cc_generic_bridge_done:
Sep 14 15:47:44.483: //11/5AD06168809A/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x3, Destination Call Id=12)
Sep 14 15:47:44.483: //12/5AD06168809A/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x3, Destination Call Id=11)
Sep 14 15:47:44.483: confID:0x3; callEntry1 callID1:0xB, type:3; callEntry2 callID2:0xC, type:6
Sep 14 15:47:44.483: //12/5AD06168809A/CCAPI/cc_api_caps_ind:
Destination Interface=0x3D28D214, Destination Call Id=11, Source Call Id=12,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_PEER_CAPS
Sep 14 15:47:44.483: //11/5AD06168809A/CCAPI/cc_api_caps_ind:
Destination Interface=0x3EB9F6C8, Destination Call Id=12, Source Call Id=11,
Caps(Codec=0x4, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=20, Signal Type=2)
Sep 14 15:47:44.483: //11/5AD06168809A/CCAPI/cc_api_caps_ack:
Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=19)
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_PEER_CAPS_IND
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Sep 14 15:47:44.483: //12/5AD06168809A/CCAPI/cc_api_caps_ack:
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_PEER_CAPS_ACK,
Sep 14 15:47:44.483: //11/5AD06168809A/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=11
Sep 14 15:47:44.483: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/Error/sipSPI_ipip_set_history_info_header:
Not SIP2SIP mode
SIP: (11) Group (a= group line) attribute, level 65535 instance 1 not found.
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:3EB9E6F8
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_RESP_SDP_SENT
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Sep 14 15:47:44.483: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Sep 14 15:47:44.487: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:44.487: //11/5AD06168809A/SIP/State/sipSPIChangeStreamState: Stream (callid = 11) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Sep 14 15:47:44.487: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Sep 14 15:47:44.487: //11/5AD06168809A/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x3, Call Id1=11, Call Id2=12
Sep 14 15:47:44.487: //12/5AD06168809A/CCAPI/cc_api_voice_mode_event:
Call Id=12
Call Entry(Context=0x23B2DA44)
Sep 14 15:47:44.487: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:8334336@10.26.2.2:5060>;tag=250D7B0-266D
Require: 100rel
RSeq: 3913
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <sip:4336@10.26.2.2>;party=called;screen=no;privacy=off
Contact: <sip:8334336@10.26.2.2:5060>
Supported: sdp-anat
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 1782 3912 IN IP4 10.26.2.2
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
m=audio 16396 RTP/AVP 18 121
c=IN IP4 10.26.2.2
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:121 frf-dialed-digit/8000
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:44.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Min-SE: 120
Content-Length: 0
Sep 14 15:47:44.775: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:44.775: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:44.987: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:44.987: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:45.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Min-SE: 120
Content-Length: 0
Sep 14 15:47:45.775: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:45.775: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 14 Sep 2018 15:47:45 GMT
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:45.987: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:45.987: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:47.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Min-SE: 120
Content-Length: 0
Sep 14 15:47:47.775: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:47.775: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 14 Sep 2018 15:47:47 GMT
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:47.987: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:47.987: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:51.771: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Min-SE: 120
Content-Length: 0
Sep 14 15:47:51.775: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:51.775: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 14 Sep 2018 15:47:51 GMT
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:51.987: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:51.987: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:55.987: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:55.987: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:59.771: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Min-SE: 120
Content-Length: 0
Sep 14 15:47:59.771: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:59.775: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 14 Sep 2018 15:47:59 GMT
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:47:59.987: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:47:59.987: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Require: 100rel
RSeq: 3913
Supported: sdp-anat
Content-Length: 262
v=0
s=SIP Call
c=IN IP4 10.26.2.2
t=0 0
c=IN IP4 10.26.2.2
a=fmtp:18 annexb=no
a=fmtp:121 0-15
a=ptime:20
Sep 14 15:48:03.987: //11/5AD06168809A/SIP/Error/act_sentrel1xx_wait_prack:
Out of retries state:11
Sep 14 15:48:03.987: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
No Inbound Container Created !!!
Sep 14 15:48:03.987: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
Sep 14 15:48:03.987: //11/5AD06168809A/CCAPI/cc_api_call_disconnected:
Cause Value=102, Interface=0x3D28D214, Call Id=11
Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
Sep 14 15:48:03.987: //11/5AD06168809A/SIP/State/sipSPIChangeState: 0x3EA4BA40 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
Sep 14 15:48:03.987: //11/5AD06168809A/SIP/State/sipSPIChangeState: 0x3EA4BA40 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
Sep 14 15:48:03.987: //11/5AD06168809A/CCAPI/ccConferenceDestroy:
Conference Id=0x3, Tag=0x0
Sep 14 15:48:03.987: confID:0x3; callEntry1 callID1:0xB, type:3; callEntry2 callID2:0xC, type:6
Sep 14 15:48:03.987: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_XCODER_RESET_STREAM
Sep 14 15:48:03.987: //11/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 14 15:48:03.987: cc_api_get_xcode_stream : 4936
Sep 14 15:48:03.987: //12/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 14 15:48:03.987: //11/5AD06168809A/SIP/State/ccsip_cnfsm_debugs: IPIPMS:next_state:S_IPIP_MEDIA_SERV_STATE_IDLE
Sep 14 15:48:03.987: //11/5AD06168809A/CCAPI/cc_api_bridge_drop_done:
Sep 14 15:48:03.987: //12/5AD06168809A/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=11, Disposition=0x0, Tag=0x0
Sep 14 15:48:03.987: //11/5AD06168809A/CCAPI/cc_generic_bridge_done:
Sep 14 15:48:03.987: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 504 Gateway Timeout
Reason: Q.850;cause=102
Content-Length: 0
Sep 14 15:48:03.987: //12/5AD06168809A/CCAPI/ccCallDisconnect:
Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Sep 14 15:48:03.987: //12/5AD06168809A/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Sep 14 15:48:03.991: //11/5AD06168809A/CCAPI/ccCallDisconnect:
Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
Sep 14 15:48:03.991: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Sep 14 15:48:03.991: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Sep 14 15:48:03.999: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Sep 14 15:48:03.999: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Sep 14 15:48:04.075: //12/5AD06168809A/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3EB9F6C8, Tag=0x0, Call Id=12,
Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Sep 14 15:48:04.075: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 14 15:48:04.075: :cc_free_feature_vsa freeing 233B8070
Sep 14 15:48:04.075: vsacount in free is 1
Sep 14 15:48:04.487: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
Sep 14 15:48:05.487: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
Sep 14 15:48:07.487: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
Sep 14 15:48:11.487: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
Sep 14 15:48:15.487: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
Sep 14 15:48:15.767: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Min-SE: 120
Content-Length: 0
Sep 14 15:48:15.771: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Sep 14 15:48:15.771: //11/5AD06168809A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:3EB9D518
Sep 14 15:48:15.771: //11/5AD06168809A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Sep 14 15:48:15.771: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 14 Sep 2018 15:48:15 GMT
Supported: replaces
Require: timer
Supported: timer
Content-Length: 0
Sep 14 15:48:19.487: //11/5AD06168809A/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
Sep 14 15:48:23.487: //11/5AD06168809A/SIP/Error/act_disconnecting_wait_ack:
Out of retries
Sep 14 15:48:23.487: //11/5AD06168809A/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x3D28D214, Tag=0x0, Call Id=11,
Sep 14 15:48:23.487: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 14 15:48:23.487: :cc_free_feature_vsa freeing 233B8150
Sep 14 15:48:23.487: vsacount in free is 0
Sep 14 15:48:23.487: //11/5AD06168809A/SIP/State/sipSPIChangeState: 0x3EA4BA40 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
Sep 14 15:48:23.487: //11/5AD06168809A/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x3EA4BA40
Destn SIP Req Addr:Port : 10.166.4.1:5062
Sep 14 15:48:23.487: //11/5AD06168809A/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.26.2.2
Source IP Port (Media): 16396
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 102
Disconnect Cause (SIP) : 504
Here below is the running-config about the voice configuration on my CISCO 2911:
version 15.3
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.153-3.M5.bin
boot-end-marker
aqm-register-fnf
card type e1 0 1
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
ip spd mode aggressive
ip spd queue threshold minimum 998 maximum 999
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 10.166.4.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
emptycapability
h225 id-passthru
h225 connect-passthru
h245 passthru tcsnonstd-passthru
sip
min-se 120
voice class codec 1
codec preference 1 g729r8
codec preference 2 g726r16
codec preference 3 g726r32
codec preference 4 g711ulaw
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
hw-module pvdm 0/0
redundancy
controller E1 0/1/0
line-termination 75-ohm
pri-group timeslots 1-31
description "------------[#TRUNK#]"
translation-rule 5
Rule 0 ^4 8334
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn sending-complete
no cdp enable
control-plane
voice-port 0/1/0:15
cptone BR
timeouts call-disconnect 3
timeouts wait-release 2
bearer-cap Speech
mgcp fax t38 ecm
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
dial-peer voice 9 voip
preference 1
destination-pattern 8......
translate-outgoing calling 5
session protocol sipv2
session target ipv4:10.166.4.1
voice-class codec 100
dtmf-relay cisco-rtp rtp-nte h245-signal h245-alphanumeric
no vad
dial-peer voice 39 voip
preference 2
session target ipv4:10.166.4.9
no vad
dial-peer voice 1 voip
no voice-class sip associate registered-number
dtmf-relay h245-alphanumeric cisco-rtp
no vad
dial-peer voice 1000 pots
destination-pattern 8334[034]..
progress_ind alert strip
port 0/1/0:15
forward-digits 4
gatekeeper
shutdown
scheduler allocate 20000 1000
ntp update-calendar
ntp server 10.52.180.25 prefer
end
I was wondering about the ISDN call-leg but when I turn on the isdn debugs and I try to call, nothing reachs the ISDN call leg.
As I said before, calls originated from PABX towards SIP SERVER are running without any problems.
Calls originated from the SIP Server towards PABX are presenting the problem (the calls never reach the PABX where the end users are).
By the way, the PABX is programmed to receive 4 digits.
Any Ideas ?
Thanks in advance.
Bruno Fraga
0 Replies 0
