Smartport System Variables
gfavarato
I'm writing custom Smartport macros and it appears that there are system variables that are not documented anywhere.  The documentation clearly shows how you can add custom variables, but all examples reference the following system variables:
$LINKUP
$INTERFACE
$TRIGGER
$AUTH_ENABLED
Is there a document that describes these system variables and others? Below is an example from the Smartport documentation.
Matt
Config# macro auto execute CISCO_CUSTOM_EVENT {
if [[ $LINKUP -eq YES ]]; then
conf t
interface $INTERFACE
description asp3-link-UP i.e. Custom Macro OFF
no macro description
switchport
switchport mode access
switchport access vlan $ACCESS_VLAN
spanning-tree portfast
exit
end
fi
if [[ $LINKUP -eq NO ]]; then
conf t
macro description $TRIGGER
description asp3-link-DOWN i.e. Custom Macro ON
exit
end
fi
TPaine
Were you able to find any information regarding this question?
