Showing results forĀ
Search instead forĀ
Did you mean:Ā
SNMP ASR920 Eventlog
alpha76
We have a network monitoring application that is running an SNMP walk on our IT infrastructure but I am having an issue with the ASR920, which is running on asr920-universalk9_npe.16.06.01.SPA image
The event log on our NMS receives interface speed changes (see below) on a L2 service instance interface, however this does not happen with any of the other EVC's on this router.
Te0/0/27.SI.255 Interface changed (attrib): [speed]
There's nothing in the router logging suggesting a change in speed and the NMS data does not change except for the packets, so I can only assume that it is reading the wrong OID??
Could anyone here please explain how I would go about fixing this?
Many thanks in advance
0 Replies 0
