SNMP - ciscoPingMIBObjects
mmunarriz
Community Member
Hi, I have tested many SNMP softs and tools. Already I have compiled CISCO MIBS.
But the problem is I can't use ciscoPingMIBObjects because the remote routers c1811 reject the request. I don't know how to upload ciscoPingMIBObjects into these routers. Thanks.
Joe Clarke
You can't upload MIBs to routers. IOS comes precompiled with all the MIBs it will support in a given version.
Please post exactly the OIDs you are setting to use the PING-MIB, and how you're setting them.
Thank you very much Joe.
Im thinking in a way to check a remote device c1811 with two links up to central office, a main Fram-relay link (70ms delay) and a backup satelital link (800ms delay).
So i want to know when the backup is active because the main link is down.
The idea is using CISCO-PING-MIB
ciscoPingDelay
OID: 1.3.6.1.4.1.9.9.16.1.1.1.7
to set a monitor parameter in my SNMP tool, for example 500ms, and compare the answer from the remote device, then i can choose diferent icons o colors to represent which link is active.
If you have any other idea it is welcome!
Great reguards
You'll need to set more than just ciscoPingDelay to create a PING-MIB operation. The following would tell device 11.1.1.1 to send five ping probes to 10.1.1.1 with a delay of 500 ms. This assumes you're using the net-snmp (http://net-snmp.sourceforge.net) toolchain:
snmpset -v 1 -c private ciscoPingEntryStatus.333 i 6
snmpset -v 1 -c private 11.1.1.1 ciscoPingProtocol.333 i 1 ciscoPingAddress.333 x "0a 01 01 01" ciscoPingDelay.333 i 500 ciscoPingEntryOwner.333 s jclarke ciscoPingEntryStatus.333 i 4
