SNMP enable traps
tom.miller1
Hi all
I am wanting to set up monitoring on our Routers and Switches we have here.
Currently we are using Node manager to intergrate into this, but wanting to setup snmp-enable traps to target the errors / messages of meaning.
What i am looking to do is monitor a) that the device is responsive on the network b) that it has no issue with communicating on either its stack / neighbour c) that if it is a router with a intergrated BRI card for example that it can see the ISDN line as up and running.
Additional items for monitor might be needed at a later date.
My thoughts were to use the traps: bgp, entity, envfan, envpower, envshutdown and isdn.
Would this do what i was needing it to do ?
regards
AFROJ AHMAD
it is always up to the customer ,what he want to monitor but still above looks fine..
you can also enable traps for
snmp-server enable traps snmp [authentication] [linkup] [linkdown] [coldstart] [warmstart]
snmp trap link-status
http://www.cisco.com/c/en/us/td/docs/ios/12_2/configfun/command/reference/ffun_r/frf014.html
Thanks-
Afroz
**Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Thanks-
Afroz
