SNMP equivalent OID to IOS CLI output
smallteabag
I'm looking for OID for VPDN Session Limit
Closest OID I came across is this - 1.3.6.1.4.1.9.10.51
Walk this OID to get the Limit. 1.3.6.1.4.1.9.10.51.1.2.1.1.1
The actual OID here is "1.3.6.1.4.1.9.10.51.1.2.1.1.1" and there are 3
index values (Z.XXXXX.YYYY)
Note that the value that we are looking at belongs to the
"ciscoVpdnMgmtExtMIB" which is just an extension of the
"ciscoVpdnMgmtMIB".
Hence the index values for both these MIBs are defined in the
"ciscoVpdnMgmtMIB".
Refer description here -
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=T
ranslate&objectInput=1.3.6.1.4.1.9.10.51
The 3 index values are as below:
cvpdnSystemTunnelType
<http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=
Translate&objectInput=cvpdnSystemTunnelType> (2)
cvpdnTunnelAttrTunnelId
Translate&objectInput=cvpdnTunnelAttrTunnelId> (63392)
cvpdnSessionAttrSessionId
Translate&objectInput=cvpdnSessionAttrSessionId> (7001)
Refer -
ranslate&objectInput=1.3.6.1.4.1.9.10.24.1.3.2.1#oidContent
So the index values can differ on each device
