SNMP interaction logging
Aggron
Community Member
If I access a Cisco device (switch, router, firewall, WAP, etc) that is configured to respond to SNMP queries is there anyway to know or to "trap" when the device responds to a query? For example, I query for device uptime. Is there any (or can there be a) reflex from the device to record that query, transmit a syslog, or "trap" on the query the date, time, and IP of the device that queried said device?
I've previously only ever really had to configure SNMP on Cisco devices. I've never been involved with the querying of said devices. I know there are programs like SNMPc or Solarwinds that can actually do queries to the devices or receive the traps from them. My initial Google-Fu and interactions with GenAi keep getting distracted with providing setup instructions.
2 Accepted Solutions
Mark Elsen
   - No , that is not possible, the idea is that SNMP will always remain authorized by configuring strong communities, snmpv3 , ACL's for restricting snmp access ,  firewalling...
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
@Aggron wrote:
Vaguely, I though maybe you could use a "permit all" ACL that is set to log the ACL use and then apply it SNMP. You probably then can tell what IPs / devices are using SNMP. But, you won't know what the query was.
And I suppose, you could maybe do something like - i dunno - maybe setup a SPAN session and then have some IDS or Splunk or something record the SNMP traffic to catalogue the raw queries and replies for future consideration. Maybe some plugin or DPI could sift though and sort out the data. But, that's going way too deep into forensics. The hypothetical wasn't asking that.
The hypothetical was literally just: "Joe Bob uses SNMP to query a router" - is there any on-device logging or configurable telemetry to know what they queried for?
Which I'm now pretty confident in saying, the answer is no. And just protect SNMP by using v3 and applying and ACL.
Yup, that's pretty much sums up my thinking too.
6 Replies 6
Aggron
Community Member
Just edited the OP because I read read it and recognized that I left out the Cisco device is configured for and responding to SNMP queries (leaving that out is confusing and bad).
Mark Elsen
  M.
Aggron
Community Member
Thanks Marce - that's good info to know. I asked because a co-worker asked me this as hypothetical question. My first response was just to just say, "Only use v3" place and ACL on it - but, I was curious about the base case.
My inclination was to say, "no" myself. But, I've never really dabbled in how SNMP actually operates.
Joseph W. Doherty
Possibility (?) crude monitoring might be done using an EEM script watching for some stat to increment, that would reflect a SNMP query or even, if possible, EEM monitoring embedded packet capture.  But if something like the foregoing is possible, it may not be possible to obtain the level of detail you seek.
I don't believe SNMP was ever envisioned providing such information itself.  SNMP provides a protocol for network management communication, but doesn't, I believe, fully detail what data needs to be communicated.  For example, a vendor device MIB often has vendor/device specific data.
