Cisco Catalyst 9200 - SNMP traps
LAN team
We have three SNMP servers configured on a switch and a lot of snmp-trap configured also on switch.
I want to disable sending of these snmp traps for one of the three servers but keep trap for the two others.
Is there a way to do that ?
Thank you.
Torbjørn
You should enter the same snmp-server command for these servers but omit the "trap" or "notification" keyword. For example: snmp-server host 203.0.113.1 version 2c yourcommunitystring
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
ok
