SNMP MIB OID for Supervisor Engine
nathan.edwards1
Is there a MIB entry that will have the supervisor model, if present?  I am trying to generate an inventory report that includes the type of supervisor engine but cannot seem to find an OID that is consistant across different platforms to query for the info.
Nate
Rolf Fischer
Level 9
Level 9
Nate,
you can find such information in the ENTITY-MIB. The exact object instance depend on model and hardware configuration (which slot contains the SE).
Two examples:
ENTITY-MIB::entPhysicalContainedIn.1000 = INTEGER: 2
ENTITY-MIB::entPhysicalName.1000 = STRING: Linecard(slot 1)
ENTITY-MIB::entPhysicalDescr.1000 = STRING: Supervisor IV with 2 1000BaseX GBIC ports
ENTITY-MIB::entPhysicalModelName.1000 = STRING: WS-X4515
ENTITY-MIB::entPhysicalContainedIn.6000 = INTEGER: 6
ENTITY-MIB::entPhysicalDescr.6000 = STRING: WS-SUP720-3B 2 ports Supervisor Engine 720 Rev. 5.9
ENTITY-MIB::entPhysicalModelName.6000 = STRING: WS-SUP720-3B
Rolf
