Hi Amol,
I not sure I understand your question. Do you mean that if you poll the same MIB on different switches that the format is different?
This should not be so. If you are walking the IF-MIB for any device than each entry in the table should have consistent properties.
For instance, the ifAdminStatus object should always use OID 1.3.6.1.2.1.2.2.1.7 and return an INTEGER.
What could be different for two identical switches (same hardware) is the ifIndex for the same physical interface.
On a first 3560, GigabitEthernet0/1 could be ifIndex 644. On a second identical 3560, GigabitEthernet0/1 could be ifIndex 643.
At least, configure āsnmp-server ifIndex persist Ā» so that ifIndex remain persisent even if the switch reboots.
Hope this helps.
Cheers,
JF
