SNMP Monitoring of power
UKDanny666
Evening All,
We have two WS-C3650-48PS-S and we are putting redundant power supplies in each, these switches are not stacked. Im a bit stuck as to how to get SNMP to create an alert when a power supply fails, then add that as a node in solar winds (will ask there for the solar winds part unless anyone has a suggestion?).
Thanks in advance for any help.
Danny
sp-netops
You will need upload the mib, rf-mib from memory.
However what you want to do seems not working as the documents says. I am trying the same thing and failed. Nobody here has an answer.
