Hello everyone, I have a few voice gateways with some E1 links which have 15 outgoing and 15 incoming channels at each link. Using a SNMP monitoring tool I am able to get the number of active calls by querying the OID 1.3.6.1.4.1.9.10.19.1.1.9.1.3 called cpmDS1ActiveDS0s within the CISCO-POP-MGMT-MIB.
The thing is, this OID only works for some router models and more specifically it is not working for newer 3900 ISR and VG350 gateways.
Does anyone have a similar OID that I can use for monitoring active calls on an E1 link?
Any help will be greatly appreciated.
