SNMP OID for retrieving PVST statistics
MICHAEL HORNE
I have been trying to search for the correct SNMP OId / MIB to retrieve pvst statistics.
Specifically, I would like to be able to poll for the topology change counter for PVST for a particular VLAN.
Does such a MIB / OID exist?
Can someone point me in the correct direction?
Many thanks
Vinod Arya
For PVST details you have to follow CISCO-STP-EXTENSIONS-MIB for PVST details and BRIDGE-MIB for PVST topology chnages.
Such as OID to see if PVST is enabled or not :
ObjectstpxPVSTVlanEnable
OID1.3.6.1.4.1.9.9.82.1.2.2.1.2
TypeINTEGER
Permissionread-write
Statuscurrent
Values1 : enabled
2 : disabled
3 : notApplicable
MIBCISCO-STP-EXTENSIONS-MIB ;   -   View Supporting Images this link will generate a new window
Description"Indicates whether Spanning Tree PVST+
Protocol is enabled for this Virtual LAN. If
Spanning Tree PVST+ Protocol is not supported
on this VLAN, then notApplicable(3) will be
returned while retrieving the object value for
this VLAN.
If the device only supports a single global
Spanning Tree PVST+ Protocol enable/disable
for all the existing VLANs, then the object
value assigned to this VLAN will be applied
to the object values of all the instances
in this table which do not have the value
of notApplicable(3).
If the value of stpxSpanningTreeType is neither
pvstPlus(1) nor rapidPvstPlus(5), then the value
of stpxPVSTVlanEnable for this VLAN can not be
changed."
For Topology details, you have to see following :
 dot1dStpTimeSinceTopologyChange OBJECT-TYPE
       SYNTAX      TimeTicks
       UNITS       "centi-seconds"
       MAX-ACCESS  read-only
       STATUS      current
       DESCRIPTION           "The time (in hundredths of a second) since the
           last time a topology change was detected by the
           bridge entity.
           For RSTP, this reports the time since the tcWhile
           timer for any port on this Bridge was nonzero.
       REFERENCE
           "IEEE 802.1D-1998 clause 14.8.1.1.,
           IEEE 802.1w clause 14.8.1.1."
       ::= { dot1dStp 3 }
   dot1dStpTopChanges OBJECT-TYPE
       SYNTAX      Counter32
       STATUS      current
       DESCRIPTION           "The total number of topology changes detected by
           this bridge since the management entity was last
           reset or initialized.
Moreover you can enable STP traps for topology change :
snmp-server enable traps bridge topologychange
Please check.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thank you for your answer.
Regarding "dot1dStpTopChanges", I want to look for topology changes for a specific VLAN, for example VLAN 300.
For me "dot1dStpTopChanges" looks like what I need when I am not running per vlan spanning tree, or it will give me the number of topology changes for all VLANs.
Unless there is a Cisco prpprieary way to send the VLAN to dot1dStpTopChanges to get the VLAN specific value, then this is not going to give me what I am after.
Hello Vinod,
I did soome mogre "googling" on this and you can use the standard mib per VLAN ... atleast on Cisco ... using "community string indexing":
http://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/40367-camsnmp40367.html
