10-20-2016 05:52 AM
HI all,
i was looking a way to get via SNMP the "real Bandwidth" for large number of WAN CPEs. I don't need to know the load but the max available transmit rate .
I had a look at CEs config and noticed that ISP does not use "bandwidth xxxx" command in WAN interface configuration that will be easy to get via SNMP, but due to the fact in many cases it involves shaped links on Fast or Giga interfaces and to reserve 9Kbps for telnet and ssh for management pourpose they always configure a policy-map and COS.
For exaples a 20 Mbit link has a FastEthernet as phisical interface on router limited to 20 Mbps with a COS/policy-map (see examples below about a 20Mbit )
Is there a MIB/OID to get the "shape average" value for show running or "cir" for show policy-map commands?
Could anyone link me the right one ?
Is there any other method to get the real bandwidth value for WAN interfaces ?
Thank you in advance for help
ROUTER A (20Mbit link)
OUTPUT from "show running" on ISP CE
policy-map BLAHBLAH
class ce_ef_input
class ce_af4_input
class class-default
kadhakdhkasd
alkdsaldjalj
shape average 19800000 198000
OUTPUT from "show policy-map" on ISP CE
policy-map BLAHBLAH
blah blah blah
blah blah blah
Class class-default
Average Rate Traffic Shaping
cir 19800000 (bps) bc 198000 (bits)
Solved! Go to Solution.
10-21-2016 03:12 PM
Hi Emiliano,
It appears the info you are looking for is related to QoS configuration. The QoS info is provided by the CISCO-CLASS-BASED-QOS-MIB (1.3.6.1.4.1.9.9.166).
This is a very large MIB with several tables that contain various pieces of the config. I would recommend running a complete Walk on this MIB and try to look into the results for any value reported that matches the "shape average" value you are looking for (i.e. 19800000).
This should point to the proper OID that provides the info you are looking for.
Luis
10-21-2016 03:12 PM
Hi Emiliano,
Luis
