snmp Problem - CISCO-MEMORY-POOL-MIB - IOS 12.2(33)SXH
sthon-dbsys
after upgrade to IOS 12.2(33)SXH, snmp memory pool doesn't show correct size
System:
cisco WS-C6504-E (R7000) processor (revision 2.0) with 1040384K/8192K bytes of memory.
Processor board ID FOX11230CH7
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
1. with IOS 12.2(18)SXF4 (s72033-advipservicesk9_wan-mz.122-18.SXF4.bin) all works fine via snmp
2. after upgrade to 12.2(33)SXH MIB (s72033_rp-ADVIPSERVICESK9_WAN-VM) wrong mem size via snmp
blni01-01#show mem
System Memory: 1048576K total, 693733K used, 354843K free, 1000K kernel reserved
Lowest(b) : 358957056
1.3.6.1.4.1.9.9.48.1.1.1.5.1 ciscoMemoryPoolUsed
1.3.6.1.4.1.9.9.48.1.1.1.6.1 ciscoMemoryPoolFree
oper@ffm002nvz:/lanbf/home/oper/cfgdmz>snmpwalk -c xxxx blni01-01 .1.3.6.1.4.1.9.9.48.1.1.1.5
cisco.ciscoMgmt.48.1.1.1.5.1 : Gauge: 219250804 <--- WRONG DATA
cisco.ciscoMgmt.48.1.1.1.5.3 : Gauge: 7066320
oper@ffm002nvz:/lanbf/home/oper/cfgdmz>snmpwalk -c xxxx blni01-01 .1.3.6.1.4.1.9.9.48.1.1.1.6
cisco.ciscoMgmt.48.1.1.1.6.1 : Gauge: 379497380 <--- WRONG DATA
cisco.ciscoMgmt.48.1.1.1.6.3 : Gauge: 1322288
I tried the enhanced mempool mib, but also don't get the memory shown in "show mem".
(I also dont understand the returned 9 values, any ideas ? )
CISCO-ENHANCED-MEMPOOL-MIB.my
ftp://ftp.cisco.com/pub/mibs/oid/CISCO-ENHANCED-MEMPOOL-MIB.oid
1.3.6.1.4.1.9.9.221.1.1.1.1.7 cempMemPoolUsed
1.3.6.1.4.1.9.9.221.1.1.1.1.8 cempMemPoolFree
oper@ffm002nvz:/lanbf/home/oper/cfgdmz>snmpwalk -c xxxx blni01-01 .1.3.6.1.4.1.9.9.221.1.1.1.1.7
cisco.ciscoMgmt.221.1.1.1.1.7.1001.1 : Gauge: 318063608
cisco.ciscoMgmt.221.1.1.1.1.7.1001.2 : Gauge: 4456288
cisco.ciscoMgmt.221.1.1.1.1.7.1001.3 : Gauge: 3881868
cisco.ciscoMgmt.221.1.1.1.1.7.1017.1 : Gauge: 412859588
cisco.ciscoMgmt.221.1.1.1.1.7.1017.2 : Gauge: 7066144
cisco.ciscoMgmt.221.1.1.1.1.7.1017.3 : Gauge: 5753632
cisco.ciscoMgmt.221.1.1.1.1.7.2001.1 : Gauge: 21264376
cisco.ciscoMgmt.221.1.1.1.1.7.2001.2 : Gauge: 4366400
cisco.ciscoMgmt.221.1.1.1.1.7.2001.3 : Gauge: 1883208
oper@ffm002nvz:/lanbf/home/oper/cfgdmz>snmpwalk -c xxxx blni01-01 .1.3.6.1.4.1.9.9.221.1.1.1.1.8
cisco.ciscoMgmt.221.1.1.1.1.8.1001.1 : Gauge: 504067068
cisco.ciscoMgmt.221.1.1.1.1.8.1001.2 : Gauge: 501948404
cisco.ciscoMgmt.221.1.1.1.1.8.1001.3 : Gauge: 795572
cisco.ciscoMgmt.221.1.1.1.1.8.1017.1 : Gauge: 1115091932
cisco.ciscoMgmt.221.1.1.1.1.8.1017.2 : Gauge: 364698932
cisco.ciscoMgmt.221.1.1.1.1.8.1017.3 : Gauge: 897388
cisco.ciscoMgmt.221.1.1.1.1.8.2001.1 : Gauge: 110818988
cisco.ciscoMgmt.221.1.1.1.1.8.2001.2 : Gauge: 108842772
cisco.ciscoMgmt.221.1.1.1.1.8.2001.3 : Gauge: 453292
blni01-01#show module
Mod Ports Card Type Model Serial No.
1 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAL1128U3EN
4 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL1130VVHP
Mod MAC addresses Hw Fw Sw Status
1 001a.2f3b.fa88 to 001a.2f3b.fa8b 5.4 8.4(2) 12.2(33)SXH Ok
4 001c.58b2.1460 to 001c.58b2.148f 1.10 12.2(14r)S5 12.2(33)SXH Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 3 WS-F6K-PFC3BXL SAL1127TX01 1.8 Ok
1 MSFC3 Daughterboard WS-SUP720 SAL1127TV5E 3.0 Ok
4 Centralized Forwarding Card WS-F6700-CFC SAL1129UW8U 3.1 Ok
Mod Online Diag Status
1 Pass
4 Pass
Joe Clarke
This is a known bug (CSCsg09784 which is a duplicate of CSCsg16388). As a workaround, you can use the following objects from the CISCO-PROCESS-MIB to get memory information for ION images:
cpmCPUMemoryUsed
cpmCPUMemoryFree
cpmCPUMemoryKernelReserved
cpmCPUMemoryLowest
I could not find the provided objects in ftp://ftp.cisco.com/pub/mibs/oid/CISCO-PROCESS-MIB.oid
They're relatively new. The OIDs are:
.1.3.6.1.4.1.9.9.109.1.1.1.1.12
.1.3.6.1.4.1.9.9.109.1.1.1.1.13
.1.3.6.1.4.1.9.9.109.1.1.1.1.14
.1.3.6.1.4.1.9.9.109.1.1.1.1.15
looks fine.
thx a lot
