06-09-2010 02:01 AM
is possible to monitor dhcp binding or free addresses using snmp? I found the following MIB: CISCO-IETF-DHCP-SERVER-MIB, but this MIB is supported only on the Cisco 7300, 7200 series.:-( When I tried snmpwalk on the Catalyst3560, but the CISCO-IETF-DHCP-SERVER-MIBoids is not supported:-( So the question is following: Is possible to monitor DHCP leases using SNMP on the low end Cisco platforms (800,1700, 1800, 26xx, 28xx..., Cat3560, Cat3560E, Cat3750, ...)? Thank you. Roman
06-16-2010 11:04 PM
You can do this with EEM and the EXPRESSION-MIB. Take a look at the script at
http://forums.cisco.com/eforum/servlet/EEM;jsessionid=BC017F546ECE38762F78BCF6270D6A77.SJ5A?page=eem&fn=script&scriptId=2283 . I just used this script today to do exactly what you want. I created objects to be able to poll my number of outstanding leases and my overall pool size.
06-17-2010 07:18 AM
Thank you very much. I will test it. Is it supported on the L3 switches (3560,
3750)??. Roman
06-17-2010 08:04 AM
Provided those switches are running 12.2(40)SE or higher, then yes.
