11-18-2006 09:07 PM
HI
I am facing a problem.
I install cisco works2000 . when I configure snmp setting option for discover metrics, i am face a problem.
In SNMP setting has option read and write community. all are know their setting by default public.
for security purpose i use in my device
snmp setting only read only like read community "cisco123"
when I setting only "cisco123" and write
community keep blank and save .
but after save i found in write community shows public. and for this reason i can not discover any device.
so my question is without write community , can i discover metrics ?? if possible how i can ?..
I expect experts are help me to provide the information.
Biplob
11-18-2006 09:43 PM
Campus Manager only requires a valid read-only community string to perform discovery. If you have configured this correctly, and discovery is not finding your devices, then there is some other problem. What version of CiscoWorks are you using?
11-19-2006 12:21 AM
HI
I uses CM 3.3
IN SNMP setting when i put readonly cisco123 and write community blank then after save it shows their "public"
but in my device I configure only
snmp-server community "cisco123" ro
NB: beside my switch have another string "noc123" ro so i should check multiple sting box check mark ?
I think you understand my problem.
thanks
biplob
11-19-2006 07:45 AM
The value of the read-write community string in Campus is not important if you are not using a read-write community string on the device. It will not hinder discovery.
You only need to enable multiple community strings if you have different community strings for the same range. For example, if you have two *.*.*.* entries, then you need to enable multiple community strings. If you are just using different community strings for different sections of your network, and you specify those sections with discrete ranges, then you do not need to enable multiple community strings. So:
*.*.*.* cisco123
*.*.*.* noc123
Requires multiple community strings. But:
10.*.*.* cisco123
11.*.*.* noc123
Does not.
