snmp setting =notifyview=
May Simpson
Hi Experts,
I am replacing switch from WS-C2960(Switch names are A-1) into WS-C2960XR(Switch names are A-2), the new switches will take over configuration from current switches WS-C2960.
I loaded command "snmp-server group Mongroup v3 auth notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F access ALC_A" which is from current configuration of A-1 into new Switch A-2, but the show run of A-2 displays as below. It doesn't show notifiy view.
snmp-server group Monadmin v3 auth
snmp-server group Mongroup v3 auth access ALC_A
The "show run all" of A-2 displays as below.
snmp-server group Monadmin v3 auth match exact notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F
snmp-server group Mongroup v3 auth match exact read v1default access ALC_A
snmp-server view v1default iso included
snmp-server view v1default internet included
snmp-server view v1default snmpUsmMIB excluded
snmp-server view v1default snmpVacmMIB excluded
snmp-server view v1default snmpCommunityMIB excluded
snmp-server view v1default ciscoMgmt.252 excluded
snmp-server view *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F iso included
snmp-server view *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F iso.2.840.10036 included
The notifyview looks different from the command from current switch A-1.
So this command "snmp-server group Mongroup v3 auth notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F access ALC_A" is not applied to new switch properly? In order to load this settings into new switch, what can I do?
The IOS version of current switches is 12.2, the one of new switches is 15.2.
Any advice will be deeply appreciated.
Best regards,
0 Replies 0
